Mine took a week in contrast…western poweraround 8-12 weeks in most cases apparently
cant they install it set up for G98 and then move it over once the paperwork comes through?Hi,
Attempting (second year) to get solar installed and have now been told we need to wait for a G99 form to be complete, any idea how long this will take ?
Thanks
It’s a strange one though as my mate got his install a week earlier, same company, same supplier - western power, but he’s still waiting to be signed off! I think it may be regional/demand relatedYou don't really want to do a G98 then find out after the install that the grid won't let you go over 3.68kWh
good point - makes a big difference on who your local network is, worth asking the installer what their recent experience has been![]()
Can you not measure it yourself?Looks like can only get 10 panels on my roof
All the guy done was measure length of house, nothing with how much distance there is from centre of roof to front of house to see if two rows would fit so I got no idea of what panels might fit cause I dont know distance from middle to front of house on roof.
Nope, 2 story house and cant get in the loft myself.Can you not measure it yourself?
City plumbing do 500w panels @ 200 bucks a piece……actually 540w at 250Jinko do 470w panels but im never breaking a 5kw system unless I can get 2 rows of 500w panels.
So whats the length of the house??Nope, 2 story house and cant get in the loft myself.
20ftSo whats the length of the house??
Terraced house, connected door-door on one side and arched alley on other side. Recent cladding on home will not give accurate measurements.If you can get ground measurements and a side on picture you can work out the roof space fairly easily.
Just 1) measure front and side
2) get a side photo (from perfect side position) and manually measure the angle on a photo
3) use front plus half side and angle of roof to give you missing roof dimension
If that sounds tricky get 1 and 2 and we can help you here in regards 3
You can get a pretty decent measurement just using Google Maps satellite view tbh, use the measure distance tool.
Your not fitting 10panels in two rows of five if the property length is only 20ft……20ft
Doesn't sloping skew that?
Going to have to get him to make sure what he proposes will actually fit before handing over any money.
panels are 1.77m long and 1.07m wide…….so in landscape, thats two rows of 4 or in portrait it would be tough to fit two rows unless the roof is at least 3.6mtrs to the peak due to not being allowed to go above and i think within 300mm of the peak and 300mm from the front…so only giving you 3 usable metres and you would need over 3.4mtrs to put two rows in portrait.
Thats so that wind doesnt get up under the panels and help to lift them off the roof.
