Domestic wind turbines are a nightmare to comply with planning unless you have a decent plot with the house set in the middle.
Domestic and commercial, crazy isn't it?Domestic wind turbines are a nightmare to comply with planning unless you have a decent plot with the house set in the middle.
Assuming you mean the 5kw hybrid inverter? It's any combination within the spec of the inverter itself.The 5kwh GivEnergy, anyone have any info on how much it can charge the battery and export at the same time if I cap it to 3.68kWh?
Thanks I will look into fitting more panels on. Ideally I would half like a split system with 5kw on the house and 4kw on the garage but I assume that isn’t possible.
That was my plan, I was thinking of getting the batteries in the garage if I could and have a 10mm supply cable back to the house so I could run the house from it
If you do not wish to continue with your application please let us know within 2 working days to allow us to cancel with the DNO and avoid the COE, if we do not receive a response we will assume you agree to pay and you will be invoiced for the costs.
Expert Witness Solutions
If you’ve had problems with your Renewable Energy Installation that cannot easily be resolved with the original installer and if you need someone to provide you with an objective, thorough and professional evaluation of the installation or wider situation, we can help you or your legal advisers.
As part of our commitment to quality across the industry, we offer a tailored independent auditing and expert witness service to check the work of other companies operating in the Renewable industry.
Our vast experience in providing Expert witness work has seen us working with individual customers, installers, certification bodies, Trading Standards and DECC.
We have been called to provide expert reports for an array of court cases across the UK to help settle disputes between an installer and their customer.
We have provided a presence in court on several cases to be cross examined having provided an expert report.
We have aided DECC providing written evidence for a judicial review on the scope of certification and EU definitions of product and product families.
Our principal expert witness holds the current positions within the Renewable Industry:
Our service can be tailored to fit your individual project dependent on the reason for an Expert witness to be used.
- Current Chair of the Microgeneration Certification Scheme Standards Management Group.
- Microgeneration Certification Scheme Steering Group.
- MCS Solar PV Committee.
- MCS Solar Thermal Committee.
- MCS Heat Pump Committee.
- IET – Awarded MIET post nominal for contributions made to the industry.
If you have already had a Renewable system installed that you do not believe is installed correctly or otherwise fit for purpose, we can independently assess the system on your behalf and provide a detailed report for you to use if you are having difficulty with your installer for whatever reason.
We are normally engaged by solicitors acting for policyholders in such disputes and are happy to review a case at no cost before indicating a costing for the report and the appropriate timescale in which it can be prepared.
Please contact us to discuss your requirements.
Thanks for that, we were really struggling to find anyone who provides that kind of service.@KompuKare
Take a look at this video https://www.youtube.com/live/_1vHVUAMkzs?feature=share&t=1716 the guy is from GTEC which is a training company, but they appear from the video to clearly do inspections and reports on solar installations. Actually just found the page on their website.
Expert Witness Support | GTEC
Tailored independent auditing and expert witness service to check the work of other companies operating in the Renewable industry.gtec.co.uk
Just that little two-letter word in the way then!If the government really wants to go net zero they should push renewable technologies instead of the little tap that they start then just give up on.
I knew I'd seen the video a few months back, just needed to remember to find it.Thanks for that, we were really struggling to find anyone who provides that kind of service
Some guidance would be appreciated.
I have a quote for solar panels and battery. I have no idea if the specifications are good or not.
what I have been quoted is
11 X Jinko Tiger Neo 430W N-Type All Black Mono Panels
Lux Hybrid 5kW Inverter
Emlite NET Gen meter + 5x Tigo Optimisers 9.6kWh Hanchu Ess Battery Storage (100% Usable) Roof Mounting Kit
Wi-Fi Dongle for Cloud Access
Bird Protection not included
Assumed annual electrical generation from solar panels 3595kwh.
My annual electric use in 2022 was 3900
The quote for supply and installation comes in at £11,780
Does the specification look appropriate? I may get an EV in 5 years so I would want to take that into account too.
Yes, part of the area will be in shade and yes I will add bird protection too. Does the rest look ok as I have no idea!Seriously consider bird protection
5x optimisers seems odd. Some panels potentially shaded?
Don't know about the rest, but at least that Inverter has some control over charging / discharging in the Android App:Some guidance would be appreciated.
It is a very long video with no index or anything so no wonder that's it's hard to find.I knew I'd seen the video a few months back, just needed to remember to find it.
I did exactly the same thing. I have 10 panels on the garage roof with the inverter and 11kw batteries in the garage. We dug a trench and ran new electric mains cable out to the garage and back as well as dropping in some CAT 6 cable at the same time for extending the internet access/hard connecting the inverter to the route in the house.See my build thread, link in my signature. I put in two 25mm cables, one feeds the grid to the garage, the other supplies the whole house, which means I have whole house back up.
So true off-grid which stays on when the grid is off?I've not yet wired in the emergency supply circuit but should be reasonably easy to do with the cables in place so although will need a separate earth ground in the garage apparently
They have maximised the front south facing elevation with 11 panels. The rear is north facing so I’m guessing less suitable?Seems ok. Certainly not a silly price.
Any scope for more panels?
I've got that with my system.So true off-grid which stays on when the grid is off?
Guess a separate earth makes sense for that, but I though this whole thing - power when the grid is off - was very rare in the UK? Hence why I mocked my incompetent installers having a sales pitch for it on their website; basically I suspect they don't offer this but like to get sales any which way they can.
