do you need battery stores, will selling to the grid be better option, so less cost up front. How much do you use a day on average, thats where i would be startingThat was my plan, I was thinking of getting the batteries in the garage if I could and have a 10mm supply cable back to the house so I could run the house from it
Hit a problem, my DNO won't pass this as we live on a private estate and there will be extra charges involved as they have to 'upgrade infrastructure'.I just had some quotes (from the same installer), how do these look and any advice please?
Option 1 - 7.98Kwh:
19 Jinko Tiger Neo 54c 420W N-Type All Black Mono solar panels
GivEnergy 5kW hybrid inverter
Gen2 GivEnergy 9.5kWh LiFePO4 Battery
£13099
Option 2 - 10.08kwh:
24 Jinko Tiger Neo 54c 420W N-Type All Black Mono solar panels
SolarEdge optimisers
SolarEdge 8000 HD Wave
SolarEdge 10kwh Battery
£16699
Both options + extra for bird protection.
Yes, you can have a bigger inverter and limit the export to 3.68. You will clip during peak summer time output (E.g. days like today) but it will produce a lot more over the winter than a smaller system.
How much is the reinforcement fee? If it’s only a few hundred I might be tempted. If it’s thousands then I wouldn’t bother.
No idea what the fee is, they say I will get billed automatically.
Battery # | Qty | Date | Charge start | SOC % start | Daily Charge at start | Charge end | SOC% end | SOC % change | Daily Charge at end | Calculated battery capacity | vs rated (5.12 kWh each) | Avg for bat# | [Daily Charging Energy(kWh)] from logs | Octopus between 01:00 and 04:00 |
1 | 1 | 2023-08-01 Tue | 01:00 | 16 | 0 | 02:18 | 99 | 83 | 2.4 | 2.9 | 56.5% | 2.2 | 2.4 | 2.8 |
1 | 1 | 2023-08-03 Thu | 01:00 | 11 | 0 | 01:58 | 100 | 89 | 1.5 | 1.7 | 32.9% | 2.2 | 1.5 | 1.4 |
1 | 1 | 2023-08-04 Fri | 01:00 | 11 | 0 | 01:55 | 100 | 89 | 1.7 | 1.9 | 37.3% | 2.2 | 1.7 | 1.6 |
2 | 1 | 2023-08-05 Sat | 01:00 | 11 | 0 | 01:55 | 100 | 89 | 2.4 | 2.7 | 52.7% | 2.7 | 2.5 | 2.3 |
2 | 1 | 2023-08-07 Mon | 01:00 | 11 | 0 | 02:20 | 99 | 88 | 2.3 | 2.6 | 51.0% | 2.7 | 2.5 | 3.0 |
2 | 1 | 2023-08-08 Tue | 01:00 | 13 | 0 | 02:20 | 99 | 86 | 2.5 | 2.9 | 56.8% | 2.7 | 2.4 | 3.0 |
both | 2 | 2023-08-09 Wed | 01:00 | 11 | 0 | 03:50 | 99 | 88 | 3.6 | 4.1 | 40.0% | 4.7 | 3.6 | 4.7 |
both | 2 | 2023-08-10 Thu | 01:00 | 11 | 0 | 03:50 | 98 | 87 | 4.6 | 5.3 | 51.6% | 4.7 | 4.7 | 0.3 |
They must be able to tell you the cost, it could literally be thousands or tens of thousands of pounds.No idea what the fee is, they say I will get billed automatically.
We are unable to confirm the exact costs at this stage as these are subject to change depending on the assessment by the DNO, however further information is provided on their websites on how these are applied.
If you do not wish to continue with your application please let us know within 2 working days to allow us to cancel with the DNO and avoid the COE, if we do not receive a response we will assume you agree to pay and you will be invoiced for the costs.
A solar diverter will never pay for itself, as MKW gets at but on the rest I wholly agree.
Has anyone got or looked at home wind turbines? Attached to the chimney….
