The SolarEdge designer seems to think 15 x 430 panels would fit too, but i'm not sure if i'm using it correctly
Or, as is often the case quite a bit less.You can't go too near the edges though usually, needs probably minimum of 30CM or so either side, if not a bit more.
Managed to convince MyEnergy that 15 panels should be possible.
Good to know that calling the advice rubbish was a mistake.The guy did apologise and just said he had his brain puddled by his kids and for some reason couldn't picture the layout I meant until I sent him some images.
He even said he could probably add more panels in portrait between the vents etc. but I might need optimisers too due to shading on the lower section of roof and it might not look as neat.. as well as being more expensive again.
I'd have to ask about the battery. Nothing is itemised, just a system price
I don't think they know how or where the batteries would be situated until I say go ahead and put down a refundable £100 deposit so they do a survey.
I did a ninja edit, see above.The roof is south facing more or less
Will a 5kW inverter be ok for 6.45kW panels?
Many have internal heating so they can charge properly in freezing weather.Does it make it that much better? I have seen some houses for sale that had the batteries for tesla on the outside of the house.
will be fine. worst case scenario you will get a tiny amount of clipping for a short time on really sunny but not too hot saysWill a 5kW inverter be ok for 6.45kW panels?
