odd is fine it just must not be a prime number
Is there any 101 articles that explain fully about solar panels and benefits of using batteries or not?
As above it depends on your situation. However I'd say the biggest benefit of batteries is using more of what you generate and being able to charge cheaply from the grid when there is no solar. Not to mention the ability to discharge to grid during saving sessions which can be quite lucrative (£2.25 or £4 per kWh this winter so far).Is there any 101 articles that explain fully about solar panels and benefits of using batteries or not?
Personally, I'd say having battery storage is more beneficial then having panels imho.
I've been kinda struggling with the 5kw limitation so wanted to look into upgrading the inverter
Instead of getting rid of the 5kw inverter and swapping it for an 8kw, would it be possible/make more sense to install a second 5kw inverter in parallel as master and slave?
I'll be able to tell you soon, as my NW facing array being installed on Weds will be off a second 3.6kW non-hybrid inverter running with my existing 5kW hybrid and connected via a CT clamp. I looked into a single larger hybrid inverter but decided against it as I can charge my existing batteries fine in the three hour window and it would have cost much more. In theory when it's sunny on the new array I could use or export that as well as the 5kW max on the existing inverter.Personally, I'd say having battery storage is more beneficial then having panels imho.
I've been kinda struggling with the 5kw limitation when cooking etc. so wanted to look into upgrading the inverter.
Yeah, I should have gotten the larger inverter..Split the strings, across the two and master slave is possible, less efficient than a single though and more complicated to control. I guess taking the 8.8kW as suggested would have been a good move, shame really.
i thought io had the same export limitation as go, ie the 8p export one, are you sure you can have the 15p one?My winter strategy is fairly straightforward, charge the battery to 100% each night on Octopus IO at 7.5p and not worry about the solar so much.
Summer is where I'm not sure whether to go flux or stay on OI. Having an EV throws a spanner into the work with flux and the short and high night rate makes it not so attractive and I think I'll probably be better off staying on OI.
If I stay on IO, I'll probably still charge the battery to full nightly as the export rate (15p) and just export all the excess power I generate.
Would current solar PV owners recommend it?
Seriously considering installing an array + battery for my home.
Are jinko and sunsynk good brands?
I've got a quote for 8x 440w jinko panels, 3.6 KW sunsynk hybrid inverter and a sunsynk 5kwh battery for £7k all inclusive - good deal?
Yeah that's correct, estimating a yearly use of 2000kwh, 4000kwh production and a 6 year ROI including of SEG @16p/kwh.IMO Solar + Battery is a no brainer now, especially if you can get a decent sized array, and you aren't only chasing payback times. As for the quote £7k is Ok, the battery is small but I guess you should look at your power use and max load, given your job you probably aren't really home much I'd imagine?
Not sure on that, our gas and electric was minus £406 last year (the whole year), and the additional system and batteries were only connected up late February, and due to delays with non-working smart meters we didn't start getting paid for export until April.Would current solar PV owners recommend it?
