I'm in the North East but I'd be surprised/hope it isn't that much of a reduction compared to the balmy south
Does anyone know how much RAM is required to run Home Assistant on a Pi? The official website doesn't say.
I have HA running within Hyper-V on my CCTV server. I don't have much running on HA at the moment, only Solax Inverter, Hive, and the Octopus tariff rates. I allocated the VM 512MB - 8192MB of Dynamic RAM to see how it went. I've noticed Hyoer-V Manager is reporting it's using just over 5GB.
I'm sure it would be happy with 4GB, possibly less.
Another consideration is you should mix panel types within the string.
Indeed. Most installers won't do this either. I have 400w Sharp panels and they wouldn't even mix them with the otherwise electrically identical newer 420w panels.Another consideration is you should mix panel types within the string.
Currently using 0.8Gb on a RPi 4 2gb, rock solid for over a year.Does anyone know how much RAM is required to run Home Assistant on a Pi? The official website doesn't say.
You getting a battery added on to an existing system, or that's just what you're buying with your complete system?Thanks for all your advice, going ahead with the 9.6kWh battery, should be installed in a few weeks
Hi Guys,
I've been quoted £10.8k for 16 x 435 tiger all black panels in roof, with giv energy 13.5kw AIO battery with Sofar inverter (x12 panel on pitched roof x4 on flat) south facing.
Having a new roof so roofing cost cheaper plus already paying for the scaffolding...
Does this sound reasonable?
The battery alone is about £5k ex VAT so it's about £5.8k for the panels and installation which I'd say is about right at the moment. I've just signed up for a second 11 panel system with non-hybrid inverter for £5.9k with scaffolding so very similar.Hi Guys,
