From beginning of March to the end of October should be a considerable increase.My E/W has now started matching my S. Over Dec, Jan and most of Feb the S was outperforming them.
They can do a GivEnergy 5kw hybrid & 9.5kw battery for £511 extra instead of the Luxpower/Hanchu. Lower battery charge/discharge and lower overall PV output but I wonder if the GivEnergy support and software (Octopus integrations) are worth it?It's alright, not sure what the long term support will be like with Lux and Hanchu though. Hardware costs (at retail ex. VAT) with better 415w panels and a 15kWh Fogstar battery are ~£4200, using a Solis Hybris inverter. If I were you i'd ask for them to up the panels to 435w, you can never have enough kWp.
That sounds very good, what part of the country are you in?
That's a Fox KH10.5 inverter with four PV strings. I'm guessing the 20 panels are over several different roofs? That's the only reason I can think why they've specced it over a smaller inverter.@viking3 that's a pretty high capacity inverter for a 8.3kw system, have they overspecced your inverter by mistake?
either way, that quote appears on the higher end of reasonable, mostly because the scaffolding works and installation costs are fixed, regardless of the size of system you're installing
in perspective, mine was 10x 440w, 3.6kw hybrid inverter, 5.1kwh battery for £6885 all included
i would've expected that yours would come under £11k tbh, £12k at a push
Ah that makes senseThat's a Fox KH10.5 inverter with four PV strings. I'm guessing the 20 panels are over several different roofs? That's the only reason I can think why they've specced it over a smaller inverter.
No - It's on one long south facing roof - but they just seem to use the same inverter as a quote I'd had from them for a smaller number of panels. Our local council have done a bulk purchase deal and are recommending it to residents and therefore I was hoping that the £s and the equipment used would make more sense and £s would be more competitive. I'll ask them about the inverter but sounds like I may need to get some more quotesThat's a Fox KH10.5 inverter with four PV strings. I'm guessing the 20 panels are over several different roofs? That's the only reason I can think why they've specced it over a smaller inverter.
@Martynt74
I'd go for a Quattro over a Multiplus, the Quattro has secondary input for a generator (which is a must for off-grid), the Multiplus may have the option, but I'm pretty sure that was the major benefit of the Quatro. I'd also go for different batteries, you could get 30 kWh for similar money, it is also easy to add more.
Edit. Just checked Multiplus doesn't have two inputs, so you need the Quattro. It will also be able to automatically start the generator. If you can afford it, get the largest version, it's a big investment and you don't want to find you're underpowered in a few years time.
Solar Battery Storage | Fogstar UK
When it comes to solar battery storage, we understand that choosing the right storage solution for your solar energy is crucial, which is why we offer a range of options to suit your installation.www.fogstar.co.uk
You can also buy similar direct from China.
Thats a lot of generation potential.
20kwh is quite a lot of storage, 2-3 days I would guess unless you cook a lot etc
You really need to understand your usage pattern.
I haven't converted to English, but I cannot see an obvious backup to solar. I wouldnt go off grid even in high production areas without one.
Something could fail on panels and you have no backup. Inverters can also fail, you would be without power. I would look into costs of have 2 inverter based system personally.
I would be asking to have a small generator installed. Doesnt need to be high, something like 2kwh diesel, if your batteries were getting very low due to say low solar for a week, then you would fire that up for a few hours to recharge you batteries a bit.
Your correct spain will generate a lot more and with 11kwp thats some power to kick in, although looks like the inverter is 8kwh many will accept higher, but not all so you may be capped at 8kwh.
Is your pool going to be heated at all.
When solar is doing well its can massively over generate, I could imagine you could be well into high xx kwh, maybe even touch xxx kwh per day range at peak times, which will mean you will significantly under produce compared to potential since you will have no where to send it.
Thought was could you divert to pool maybe?
Ev would also obviously be ideal, but depends on local charging for when solar isn't super strong.
Do you plan on a hot water tank, excess solar with no where else to go is also very suited to going to hot water.
In all honesty that inverter will serve you well. It'll never clip regardless of generation and you'll be able to charge and discharge the batteries at a very high rate (up to 48A) The batteries are modular so you can have up to 7 aswell at about £600 each.No - It's on one long south facing roof - but they just seem to use the same inverter as a quote I'd had from them for a smaller number of panels. Our local council have done a bulk purchase deal and are recommending it to residents and therefore I was hoping that the £s and the equipment used would make more sense and £s would be more competitive. I'll ask them about the inverter but sounds like I may need to get some more quotes
Awesome thanks guys. I'll make sure they upgrade to the Quattro as the ability to add in a diesel generator is crucial as you say.
We did consider a pool heater but sacked off the idea, mainly due to cost of the heater and also the lack of ability to get above a 5C differential, so if it's 7C outside we were told we'd only really hit 12C water temp and that's still too cold to be enjoyable. I do plan on adding a hot tub though. Would've loved a log powered one, but given we'll likely have lots of spare capacity then it makes sense to use electric.
We'll have a hot water tank though.
On the panels, i assume the 11kwp is at peak capacity, so overspeccing on panels but only having an 8kw inverter means we're more likely to hit the 8kw level even in sub optimal conditions.
Do you guys have any thoughts on the arrays which track the sunlight and adjust? Not sure whether it's needed as much in somewhere like Spain vs further north where you may get much more lower sun day.
The HV25s are high voltage. My five run at about 260v so in theory at 48A they can charge/discharge up to 12kW if warm enough.@reef think you might be muddled with 48A, when I grid charge I'm sending 130 Amps to the batteries, this is restricted by my 8kW inverter, when I discharge I'm often pulling 180 amps from the batteries. I would certainly not go with Pylon tech batteries, there are much better options now.
