Solar panels and battery - any real world reccomendations?
Yep, MC4 should be left disconnected on the roof until everything is connected with the isolator turned off. Then connect the MC4, no current can flow as the isolator is off, then check polarity and voltage at the isolator.
If following safe working procedures then they wouldn't be able to demonstrate an arc in the way described.
Does anyone know roughly what i'd expect cost wise for scaffold on one side of a 2 story house, flat and good access but half will need to span over a conservatory?
I'm leaning towards a no battery setup and ultra low cost (because i need the pay back to be as short as possible due to moving). So even though i'd like to go big with a nice victron setup i'm likely to just install 11/12 panels on my easier side of the roof (almost dead west), with a relatively cheap 6kW growatt hybrid inverter (to be nice to the next guy if he wants batteries). All in all comes out to about £2,000 for 5kW panels, mounts, inverter and some cabling and breakers. So with that in mind I've never ordered scaffold so wasn't sure on ball parks but i'm sure it would add a large % to overall install cost given component cost is so low. Was toying with the idea of renting a tower as a middle ground for 2 weeks which seems to come in at around £120. I'm not so concerned about being on the roof installing hooks/rails etc so the convervatory shouldn't be too much of an issue. For me the tower is a means mostly to get the panels up. I have ladders but i also don't have a death wish..
@Gammawolf at a guess I'd say £700 to £1000, may be more, I think they like to charge for the ladder frames to span the conservatory. Best bet is ring some local companies and get quotes, only way to really know.
yes that seems expensive. £8k with what battery capacity? or just a solar pv installation?
No battery I don't think, will have to check the details again.
I did ask for a quote with and without though.
Edit: No battery on the quote that I can see. The inverter is a 5kw one though.
something's not right. the £8k quote should have a battery included
after all, mine was £6.8k for 10 panels + one battery from spectra. i cannot see how a 12 panel quote for £8k is reasonable without a battery
He forgot to tell us all they are being installed on a church steeple? :p
Out of interest, has anyone just gone batteries only, it could work if you don't want solar
Like a 13.5-19kwh battery setup
Charge at cheap rate at night and deplete in the day, rinse and repeat and even dump to the grid before cheap rate
Obviously the solar is a bonus but the above should work out nicely
Be interested to know if anyone has done this
