I have a naive question but with solar panels being so cheap these day. I've seen figures of £60 a panel. (is that right?)
With enough panels and extras would it be possible to do a DIY setup for only a few thousand.
Am I wrong to believe that a lot of the cost stopping people from having solar panels is the installation cost.?
How much work is involved that could be done before a professional is need to wire it into the house.
Yes you can pick up panels for
£57 including VAT, as DIY you have to pay the VAT though.
You can get a
15kWh battery for £2500.
Then you need an inverter, cabling, rails for the panels, along with numerous other bits and pieces, it does add up but can be considerably cheaper than an installer, but you really need to know what you are doing.
You'd need a electrician for the AC work, and its hard to find one that will work with you. You need to do the G98 or G99 DNO application, although the electrician might do it (I did my own).
Its also extremely hard physical work, working on a roof at an angle, removing tiles, fitting roof hooks, but before you can do that you have to plan it out, making sure you comply with regulations. You need to install the inverter, battery, and get the cables to it, and the mains back to the CU.
Once its up and running, you then want to get paid for export, this is the biggest and most annoying hurdle, pretty much every energy supplier insists on an MCS certificate, and you won't have one, and won't get one. Octopus apparently will assess your installation, and then accept it, but a lot struggle going this route, I think I've only heard of one person on here that's been successful.
That's the sort of thing that would trigger @Ron-ski and well most people who regularly post in this thread
It's so annoying seeing vasts roofs with silly arrays or none, whole housing estates going up without a single panel, large car parks without solar roofs, if roofs and car parks were better utilised we wouldn't need to fill fields with panels.
This is how they do it in Belgium, this is actually a truck park, but the entire area is covered by a solar roof, its been there for years.
★★★☆☆ · Auto electrical service
maps.app.goo.gl
