They're available in 510w versions now too if you have 200mm to spare over the 455w panels.
Same size as my rear wall panels which I got from Powerland (very pleased with their service), except mine are 525w.
Which panels were they? All of the others in the 500-600w range seem to be >2000mm in height, whereas the Aikos are about 1950mm?Same size as my rear wall panels which I got from Powerland (very pleased with their service), except mine are 525w.
Yep, front roof is facing 195º so pretty ideal for solar. I had considered getting more for the front bit too, but I mostly agree with a previous poster that it will look very "obvious" every time we park or walk to the front door. Using just the main roof feels a bit less imposing.That's more like it, is your front roof south facing as per the picture you posted.
If you wanted more panels it might be worth seeing what they'd charge for doing in roof on the lower section.
I presume you're referring to the air con units and associated pipework, rather than the solar.
@SeatIbiza great price (as long as the inverter is included in the cost)
Be sure to check on the inverter size and make sure they aren't doing the usual and just putting in a 3.68kW one. You'll want a 5kW inverter and G99 doing really. The battery will be a Fox EP5 and it can discharge at 5kW, so it would be silly not too.Yes all in price there (I've emailed to check!). Not sure if that includes moving the old stuff to my other roof, or if that will be a bit extra but he said it wouldn't take them long to do....
thanks for that advice - appreciatedBe sure to check on the inverter size and make sure they aren't doing the usual and just putting in a 3.68kW one. You'll want a 5kW inverter and G99 doing really. The battery will be a Fox EP5 and it can discharge at 5kW, so it would be silly not too.
rear of that house looks absolutely terrible!
