The heat pump thread is that way - - - > https://forums.overclockers.co.uk/threads/heat-pumps-anyone-have-one-thought-about-it.18977253/Anyone here tried octopus heatpumps? If so how was your experience?
Might get a quote from them.
This certainly seems the better option, be interesting to see what Artisan come up with, so much for good service through.48 x Jinko Solar Co., Ltd. 440 Watt Panels (JKM440N-54HL4R-B)
1 x SigenStor EC 17.0TP (Sigenergy)
3 x SigenStor BAT 8.0 (Sigenergy)
48 x TS4-A-O, 1 x HomeMax TP
£21k installed
considering I’ve seen Tesla and 28 panels for between 14-16k that seems reasonable. Hope that goes well wished they’d do that install for me in the south.Quote Check please, had a few and this one is the best I think but wanted to check.
Average yearly usage is 7400kWh, daily average around 19kWh, plan to get an EV early 2026. Wanted to max my roof space now rather than later.
14.560kW System
32 x AIKO-A455-MAH54Mb/2S - (16 South, 16 North)
2x FoxESS EP11 Total: 20.72kWh (kit to be installed in Garage)
Fox ESS 1 x KH10.5 - 10.5kW of Inverter
Scaffolding included
MCS certificate included
Bird Mesh
G99 included
£14,750
Thoughts?
That looks to be a very good price (amazing how much cheaper it is now) and an ideal choice of inverter aswell. The batteries can charge/discharge continuously at 10kW too, but I would check if they could install the new EP11-H if you're having them in the garage as they come with built in heaters.Quote Check please, had a few and this one is the best I think but wanted to check.
14.560kW System
Bird Mesh
G99 included
£14,750
Thoughts?
Thanks, id like to also maxmise exporting too, try get every last penny out of this system.That looks to be a very good price (amazing how much cheaper it is now) and an ideal choice of inverter aswell. The batteries can charge/discharge continuously at 10kW too, but I would check if they could install the new EP11-H if you're having them in the garage as they come with built in heaters.
Should be good for over 10,000kWh per year. The north panels will generate about 60% of the south-facing ones.
It's split on both sides of roof so not all best. Still wondering if there's something else I should look at cheaper but seems 3 phase options this is good but expensive.The 48 panel 3 phase will be some system, you ll take over top place on production on this forum for sure.
A friend of mine is currently having a similar system installed utilising sigen batteries.
Just different companies. I think some people see house and decide to take ****What’s the catch between the first and second quote?
It’s twice the panels, twice the battery (and a better battery system) for the same price.
The EP11s can charge at a rate of 10.3kW, so you could fill the entire 20.7kWh of batteries in a couple of hours. As I said though, this will be slower in cold weather so some form of insulation or the EP11-H with built-in heating would be helpful on the coldest winter nights.Thanks, id like to also maxmise exporting too, try get every last penny out of this system.
according to https://garydoessolar.com/utilities/dailymodellingutility/ the battery can fully charge in 5 hours? is this correct?
ive just moved to Tomato Lifestyle tariff which gives 5 hours at 5p per kWh so this should tie in nicely
Thanks!The EP11s can charge at a rate of 10.3kW, so you could fill the entire 20.7kWh of batteries in a couple of hours. As I said though, this will be slower in cold weather so some form of insulation or the EP11-H with built-in heating would be helpful on the coldest winter nights.
got some final quotes from people i have 3 phase at home.
£21k installed
23 x Trina 445W solar panels
Fastensol pitched roof mounting system with Bird Guarding
GivEnergy 11kW 3ph Hybrid PV Battery Inverter inverter
6 x GivEnergy 3.4kWh LiFePO4 High Voltage Stackable Batteries
£20.5k installed
I am still waiting on my quote from Artisan Electrics funny, they came out in August them called me in November to ask if i still wanted a quote but it would be a couple of weeks more and still nothing. I had some more work done on roof so held off others but not all done can go ahead.
Have gone for this today. I double checked the EP11 they quoted was the heated one as the quote just said EP11 and it was. They are going to amend the quote so it’s clear.Quote Check please, had a few and this one is the best I think but wanted to check.
14.560kW System
Bird Mesh
G99 included
£14,750
Thoughts?
