Be sure to check which inverter it is. You'll want the 5kW inverter with 5.46kW of panels. It'll probably be a H1 Gen 2 inverter, so you'll want the H1-5.0E G2, not the H1-3.7E G2.I've placed the order for my new system. £7,100 includes moving my existing 6 onto my garage then 5.46kW Solar PV:
12 x 455W Panel 'AIKO Neostar + Mesh' System
5.18kW FOX ESS battery
Bird proofing (although my current doesn't have this and no issues in the 3.5 years it's been up)
Thought that was a pretty good deal. Install date due on 30th January, so I should get as much of the benefit I can out of it in 2025...!
Yes I already checked that, it's the Fox 5kW jobby.Be sure to check which inverter it is. You'll want the 5kW inverter with 5.46kW of panels. It'll probably be a H1 Gen 2 inverter, so you'll want the H1-5.0E G2, not the H1-3.7E G2.
I don’t mind a bit of a premium but I want to check the pricing is not massively out of whack?
I'd be look at TPW3 for that sort of price.
What makes you say that? I’m struggling to see the advantages.
For that money we got 40 x aiko 455w panels as part of our sigenergy 16 kWh battery, 10 inverter and gateway system plus all the paperwork, scaffolding etc
A local firm has given me this quote. Panels are 450w Solarwatt AM5 and it’s a 11.04kwh BYD HVM battery. Install is relatively tricky as we have a stone roof and the battery is going to be on the opposite side of the house to the meter and consumer unit. The firm has done a couple of recent houses and are well recommended so I don’t mind a bit of a premium but I want to check the pricing is not massively out of whack?
Thank you.Bigger capacity battery, 11kW inverter, 3x MPPT's, easily fitted out doors, proper whole home back up with gateway etc. Better software integration/control than a mixed brand system like BYD/Fronius.
I’m guessing a lot of the cost here is driven by install rather than the kit itself? I’m getting some other firms to quote but we have had issues in the past with people not willing to do it due to stone tiles etc.That’s also pretty expensive. I paid less and got a bigger east/west system from a decent brand with whole home backup a year ago and prices have dropped since.
I’d also be looking at power wall 3 if you have that sort of money to splash.
