I wanted a GivEnergy battery in April and my installer said it would be at least September to get one. I changed to Huawei and got it delivered within 6 weeks.I ordered the 8.2kwh batteries but it just seems a long wait.
My installer rang me yesterday to say they'll have my two 9.5kW batteries and gen2 inverters in two weeks time ( ordered end of March).I wanted a GivEnergy battery in April and my installer said it would be at least September to get one. I changed to Huawei and got it delivered within 6 weeks.
Ordered march...two installation dates have been and gone already. There is a serious shortage of equipment in the UK at the moment.
These are the Gen 2s - 5.0 is 5000W Nominal; 5000VA Max Apparent Power Output to the Utility Grid and 22.8A (from https://www.givenergy.co.uk/pdf/Version 2.0/Hybrid Inverter Gen 2.pdf)
This page, https://www.spenergynetworks.co.uk/pages/export_limitation.aspx seems to indicate that battery storage output is relevant but I think that the hybrid inverter max charge/discharge rate of 3600W means it should be OK for this G99 Fast Track scheme.
Would be a good opportunity for a solar compatible limited kettle
3kwh element with a dial that allows lower input level, eg 1kwh, 2kwh, 3kwh
For most people the kettle is probably the single highest usage item. Although its very short spurts typically so even a top up from the grid is going to be minor cost
I think you’re overthinking this. The inverter will kick out 3.6kw from the solar and/or battery. This will cover the kettle. In the event home demand is more more and also while switching/load managing sometimes it may draw from the grid but the amount from the grid in kwh measurement will be tiny.Can you not just get a camping/caravan kettle that is lower watts? Sure it may take longer for a brew but the peak draw should stop it needing any grid energy, that was my idea anyway.
Just worked it out - 3kW (not kWh) over 45 seconds (presuming people use their noggin and only boil a cup's worth) equals about 1p at the price cap rate of 28p/kWh.
And as @gpuerrilla points out, you could get a camping one to make sure. Water needs a certain amount of energy to be passed into it to heat to 100C, so it doesn't matter whether it's delivered at 1kw or 3kW, one will just be quicker, but use the same amount of energy in total.
SNIP... so if I was trying to keep it to 1kwh or so
I have a 5kw hybrid inverter because I have 6kw of panels and in the summer I want to be able to export as much as possible rather than clipping my production.
