- 22 Jul 2010
- Kent
thanks
You're welcome bud
You can watch that to give you some confidence whilst you wait on the parts. If you have any problems or questions come back to us.
I personally would have gone for the i3 build if you were going to definately add a GPU (it came to the same price roughly as the AMD build). I did say this earlier........
YOUR BASKET
1 x Gigabyte Z77N-WIFI Intel Z77 (Socket 1155) DDR3 Mini ITX Motherboard £98.99
1 x Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £83.99
1 x BitFenix Prodigy 'Yin' Mini-ITX Cube Case - White/Black £64.99
1 x PC Power & Cooling Silencer Mk III Series 500W '80 Plus Bronze' Modular Power Supply - White £59.99
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) £54.98
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £34.99
1 x Asus 24x DVD±RW DRW-24B5ST SATA ReWriter - Black (Retail) £17.99
Total : £427.92 (includes shipping : £10.00).
That would be a good base for an intel setup (note the wifi inc) HOWEVER you would need to add a GPU. As I said a 2nd hand 1GB 460 would be good if you could find one (£50ish). The AMD A10 APU is gaming capable and you can add a GPU later for better performance.
It's not too late to send them a webnote to adjust the order. I know the mobo isnt in stock but you can still place the order and they will ship it out once the bits are in stock
