Thanks for sharing, so was that on the current app version, last change was in JulyHad the same problem on an iPhone 7 12.4. Works fine on an ipad pro 11 (2018) & galaxy s10 though. Never did find a solution for the iPhone 7.
No not really. incidently the Bose 700 is broken on android devices at present.So does this class as a refundable item, lady at the JL show said they aren’t able to accept earphone returns, unless they are faulty, does a broken app class as a fault
Shame, they are amazingly good so I’ll sit tight and moan at the app devs in that caseNo not really. incidently the Bose 700 is broken on android devices at present.
You can get Jaybird Vistas direct from them and they have 30 day money back guarantee. Mine arrived yesterday and they are brilliant!Need to buy some new IEM's but fancy getting a bluetooth set, are these worth £179? I usually use Shure IEM's with custom tips, but I assume these will be pretty good with the NC vs. the better fitting tips I currently use.
I hate the fact you can't audition IEM's anywhere, and have to commit to them deaf, so to speak.
It is pretty phenomenal when you switch the noise cancellation to the max.I'm currentl giving the noise cancellation a good test - I had to come do some data centre maintenance and as usual for these places they're faily noisy enviroments so rather than use ear plugs I'm using the XF-1000XM3's and they're doing a superb job. I can't hear any of the DC noise over the music I'm listening to.
Good to know, I’m over at one of our DCs this week I never bother with ear plugs but I should really, will have a testI'm currentl giving the noise cancellation a good test - I had to come do some data centre maintenance and as usual for these places they're faily noisy enviroments so rather than use ear plugs I'm using the XF-1000XM3's and they're doing a superb job. I can't hear any of the DC noise over the music I'm listening to.
Hopefully you can get the app working. The default noise cancellation is good but is on the lowest setting.Good to know, I’m over at one of our DCs this week I never bother with ear plugs but I should really, will have a test
Yea am sure they will sort it outShame, they are amazingly good so I’ll sit tight and moan at the app devs in that case
It’s utter madness that Sony make us rely on their app which is shockingly poorHopefully you can get the app working. The default noise cancellation is good but is on the lowest setting.
Rubber and I went one size down the ones that came on the device. I tried the foam ones and they did not seem to feel as secure.I know everyone’s ears are different but interested in knowing which ear pads people are using from the supplied rubber or foam ones
Yes I found they felt slippery tbh .... foam ones that isRubber and I went one size down the ones that came on the device. I tried the foam ones and they did not seem to feel as secure.
Mate did you try different size earbuds? they come with multiple sizes. it sounds like you are using the wrong onesHi all,
Just wanted to add my six pence worth - just picked up a pair of these to replace my wired Bose QC20 earphones (stolen on the Paris Metro last week). Overall sound quality is not bad - mid and treble are pretty good. You have to really screw them in to get any bass though as the seal isn't as good as the Bose and the bass itself is fairly monotone (this is probably the area where the Bose win out IMO). They're very good at separating instruments out in a mix without being over analytical.
Overall I'd say it's a tie - much more punch to the Bose but better voice / separation on the Sony (I'm not a bass fanatic I just want to hear my music as it was intended).
Noise cancelling - will give them a proper trial tomorrow at work (I'm a manager in TfL so I use the tube a lot) but so far I think they're as good as the Bose from my limited trials. They don't have as good a pass through function as the Bose though.
Bad points - google assistant is absolutely useless - it failed to identify a single song I asked it to play (this was with an iPad and an iPhone - wasn't able to check it with an Android device as my only Android device was stolen with my earphones).
There's a major problem for anyone using these with a laptop or PC without an intel Bluetooth chip - basically at best you're going to have a mono headset at worst (like me) you'll have no audio at all. I've got a Surface Pro arriving on Thursday (work) so it'll be interesting to see how that pans out. Sony say they will be updating the firmware before end of the month so fingers crossed.
Oh and the Sony Connect app is pretty poor - it really doesn't tell you how best to set up your earphones.
Finally if you want these in Black the only retailer who seems to have them readily available surprisingly is Argos - I ordered mine at 10 pm Saturday and picked them up at 10 am Sunday so not bad going (something I never thought I'd say about argos).
I'll see what gem Sony Support come back with tomorrow, I have just tried to add them to a friends iPhone at work and still the same issueSince they're truly wireless, it may be that they suffering from intermittent connection issues, and as such they are not fit for purpose so they are faulty and John Lewis need to accept a return.
Then promptly go ahead and buy a different set from somewhere else to see if you're having the same issue as your main issue!
I’m running these on an iPhone 6 with iOS 12.4.I'll see what gem Sony Support come back with tomorrow, I have just tried to add them to a friends iPhone at work and still the same issue
Can anyone who has an iPhone that is actually using these please confirm on here please with IOS version and app version too
So I know I'm not going mad!!!
