How do you keep it recording when you close the app?
I want to start it recording when I leave work, so its recording for a few hours ?
i get it to email the clips
can use micro sd card but its inconvenient unless you
are certain something happened
unless you can browse the sd card remotely
which i dont know if you can or not
i am using motion detection not constant recording
my email client automatically puts the clips in a separate folder
from my inbox for convenience
Thanks for the heads up
Is there anything avalible that i can sit on my window ledge upstairs, in the front bedroom looking out onto the main road where my car is parked than i can record locally or for free ? £100 or less ?
the reolink c1 pro i picked up for 40 quid at auction
can record to micro sd
record to pc over wifi so doesnt need to be near the pc
can email you motion detection clips
can pan ,tilt remotely from phone or pc
2 way audio
can trigger a siren remotely if needed
though nearly every camera looking out through a window at night
image quality will suffer pretty badly
from low light and from reflection back from the window
