Finally got my 2632 dome installed which was very tricky to adjust the lens and the focus. Had to hold a laptop in one hand and the other to make the adjustments while standing up a ladder.
If anyone can recommend a small handheld device that can be plugged into these cameras using the supplied cable, then let me know.
Anyway, picture is perfect during the day but the nightvison is useless. It wouldn't put a patch on my 2732 bullet which is really good. I don't know what is wrong but at the minute the camera might as well be turned off at night.
I do notice that it only has a 20m IR range compared to the 30m range of the bullet version but I didn't expect there to be such a major difference. I might have to buy another 2732 bullet and stick it up along side the dome and test the two.
Does anyone have a guide to setting up ivms-4200 to record? I seem to have everything right but still can't get any recording to work even to record 24/7. Just won't happen.
Might have to stick an sdcard in it and make life easier.
