Hi,
@WJA96 You said in a previous post that: "The SD cards are really intended for power cuts".
Does this mean the power supply of the cameras is different most of the time from the power supply of the NVR? Is there a standard/professsionnal way of doing that?
I am of course aware of the use of an UPS
. The problem I see with the UPS is that you need far more battery capacity in order to keep the power for the NVR/XVR and the associated hard disk. For instance a Dahua TiOC camera takes (most of the time) 2W. Let's say that you have 6 cameras, this means 12W, so the whole bunch of cameras will draw 1A under 12V. The use of the NVR will take at least the same amount of power (hard disk always ON). And the UPS itself draws its own power and at the end you get (rough estimate) about 30-35W of power budget.
So for a newcomer like me it is tempting to secure the power only for the (critical) cameras (with local storage on SD cards). Especially since the TioC cameras have their own alarms/siren.
Since the Dahua cameras can support +/-30% voltage supply variation they should endure a battery charge/discharge voltage variations without any problems. And the battey could be recharged from a solar panel. Of course not directly but using a solar battery charger.
In this way if you're absent for 2-3 weeks the system is self-reliant. Another advantage I see for this solution is that traditionnal alarms battery powered become redundant with the surveillance cameras. In fact you can invest your money in a better surveillance cam system sparing the traditional alarm...
However I wonder if there are no unseen consequences... For instance a power cut could harm the hard disk of the NVR... Do you have any feedback onthese issues?
