I've been a long time lurker on this thread, and am close to ordering some cameras. It looks like i will be going with hikvision / dahua POE (House is already wired for it) .I have a few questions though that i was hoping someone would be able to help with.
- At the start, do i need a NVR (I will get one ultimately)? I see some cameras have built in SD cards. Do these negate the need for a NVR.
- Does either hikvision / dahua link to the like of IFTTT (for the like of turning on outdoor lights). I have seen that dahua allows you do set virtual trip wires to activate alerts.
- If i got an NVR with smart detection, does that work in tandem, or instead of any smart detection / features on a camera (e.g. dahua wizcom)?
- Has anyone painted the cameras to better blend into the house? I would ideally like black over white.
- Do you need to order the mounts / back boxes, or can the cameras be mounted direct to the wall?
. The problem I see with the UPS is that you need far more battery capacity in order to keep the power for the NVR/XVR and the associated hard disk. For instance a Dahua TiOC camera takes (most of the time) 2W. Let's say that you have 6 cameras, this means 12W, so the whole bunch of cameras will draw 1A under 12V. The use of the NVR will take at least the same amount of power (hard disk always ON). And the UPS itself draws its own power and at the end you get (rough estimate) about 30-35W of power budget.
