No, they're all on seperate trip switches
Just got 2 of the Hikvision DS-2CD2042WD-I bullet cameras and hooked them up to my synology surveillance station and i must say i am impressed. Motion detection set to use the camera and surveillance station picks up the recording just fine. Really impressed, i am looking at adding another 2 cameras to my setup another DS-2CD2042WD-I bullet and a DS-2CD2142FWD-I dome for the front door.
The only downside is the £40+ you have to pay per extra license to use on surveillance station. Had looked at a stand alone Hikvision NVR but i like the low power synology system setup so think i'll end up biting the bullet on the additional £80 for the 2 licenses.
Can someone spec me a wifi home cctv system, that can maybe run from my pc or maybe separately.
3 or 4 cameras that will be inside on the window cills
POE switch will work
any Reason you chose a dome over a turret ?
Just make sure you chose the correct focal lenght lens - if it's too wide you won't be able to see the detail
"Ïnside window"
will not work at night
Can you elaborate?
Can you elaborate?
So hopefully I'm thinking straight, If i get 3 IP cameras (with POE), connect them to a POE switch, which is connected to my network, I can then use the software they (hopefully) provide on any PC in the house (on the network) to view and record footage, the PC basically acting as the receiver ?
At night you get a REALLY bad IR reflection from the window
