Not sure if you have purchased you cams but you need to factor in if you require the use of the cams more during the day or at night. If you are at work during the day, you want excellent results so a higher MP cam would be required. The 2342 is excellent during the day but pretty rubbish at night.
If at night then you will need additional lighting or a darkfighter. They are low level light 0.002 lux I think but only 2MP and they are expensive as hell. The best cams that come close to a darkfighter in night mode is the DS-2CD2335FWD-I. They are 3MP and have a lux of 0.005 compared to the 2342 model which is 0.01 lux hence why they are very poor and the technology is getting dated now.
The performance of the DS-2CD2335FWD-I is excellent both day and night and they are the new generation of turrets that are low level light grade like the darkfighter. They come also with an SD slot if you don't want a NVR.
They can be purchased for less than £120. I have a batch coming in a few days to replace some 2342 cams as they aren't up to the job for night monitoring.
