It's good but won't shine as far as the other version because the emitter is fatter so would shine wider but not further.
Exactly. It should still throw relatively well and emit lots of light though
with regard the ultrafire c8, is it any good with the xml-t6 led?
The new Petzl looks extremely interesting! Glad to see them trying breaking new ground.
Comes out in July and has a list price of €125 though so not exactly cheap, hopefully adjusting the light level for you actually works well and doesn't blind you now and again.
I took delivery today of four Trustfire 3000mAh 18650 cells.
I was hoping for a capacity of at least 2500mAh from them.
Fat chance.
1A discharge current down to 3v
Cell 1: 2325mAh
Cell 2: 2153mAh
Cell 3: Testing
Cell 4: Testing
I think it's time to spend more and invest in some quality cells, such as these.
Fat chance.
Cell 1: 2325mAh
Cell 2: 2153mAh
Cell 3: Testing
Cell 4: Testing
Dude!
You know full-well that there are only two manufacturers in the world who make 3000mAh+ cells - Samsung and Panasonic
I'd go for the AW cells over the intl-outdoor ones - AW's cells have the very very best manufacturing and materials (he's just started using a new type of bond-wire between the positive terminal and the protection circuit for even better durability and safety)
- Current regulation for all output mode (no PWM flicks even at low mode)
- As low as 3mA-5mA for low output mode
- Eight programmable outputs
- Low voltage warning below 2.8V
- High mode: Constant regulated at 3040mA![]()
