Should I be looking passed just lumen count then? I was put off the XP-G Quarks because of the lower lumen count than the P20C2. The Quark UI does look perfect though!
WOW
72 pages (and 77,000+ views) of LED torch recommendations.
I have nothing to offer other than my admiration for the OPs ability to hit a nerve with the demographic here.
Not really, there has been loads of 'spec me a torch' threads and we all just seemed to stick with this one instead of making an official thread.
Can anyone recommend me a torch please? £50 budget.
Needs to be worn like this (as modeled by this rather lovely S/Sgt):
So needs to have a clip on the button end that allows it to be carried pointing down.
Really, I want 2 modes, or the ability to quickly switch between 2 modes if it has more without cycling through them: a low mode for lighting up paperwork and stuff, and a very bright mode.
The issue 55 lumen beauty is 16.5cm long, with a body diameter of 1.85cm and a head of 2.54cm. A little bit shorter would be good, and the head can be a bit bigger, but to go through the radio loop on my armour the body needs to be about that size.
For obvious reasons, it also needs to be tough! One thing thats put me off things like the Jetbeam range is the clips just push on. Not sure how well they'd last.
Batteries, either RCR123s or AAs. 123s seem better, get a brighter torch in a smaller package.
Looking at something like the EagleTac P20C2 mkII, seems to fit the bill pretty well, and if I'm reading the instructions right, you can have the low mode selected, and then jump straight to high, and then back again easily. Also like the Quark UI too.
So any recommendations, anything worth a look at?
Thanks
Surefire LX2. Little pricey though, but it's a surefire.
Cree XM-L emitter.
Surefire's are overated
If you really want a pricey light get one of these
I love mine.
That said, I LOVE my new LX2 Lumamax...
Anyone recommend a decent AA powered light with at least 2 brightness modes? Looking for it for a father's day present and my dad would not want to mess around with having to find obscure batteries etc.
The Cree C3 posted previously would be ideal if it had a low/med setting. It's hard trying to find the good ones from all the crud!
Hi guys!
I am in the market for a LED torch. I have read through the majority of this thread but am left a little confused as to what I should get.
I need the torch mainly for work on the car and keeping in the car (as its getting old and break downs are not out of the question). My budget is around £70, including batteries/chargers. Obviously the more powerful the better!
Fire some suggestions at me please!
