Are theses led torches anygood on ebay, as they are over 1000 lumens, as Im thinking to buy my first led torch?
Divide it by ten for a more realistic figure, 1000 lumens would be better then a 60w bulb which most arent. Chinese new year now so they'll not be sending anything, week long holiday
I think all the ones posted would be the same one basically, just a nicer handle on one. Presumably they did more then that but I'd guess they are similar light output
I got the sanyo enloops last posted, seem very good for plain AAA. Not much point getting a cheap 18650 setup instead if you can use either though mine were free. A proper high discharge 18650 I dont know how much better it is as Ive yet to buy
usb charger, out of stock and its cheap but does the job afaik - http://www.amazon.co.uk/Mobile-Powe...qid=1390161707&sr=8-58&keywords=18650+charger
cheaply finished torch, but brighter then old chunky 1 kilo handheld - http://dx.com/p/sh-98-cree-xm-l-u3-...light-black-1-x-18650-26650-or-3-x-aaa-222879
china is closed but this in uk should arrive by weekend and I'd guess its ok, Ive had similar - http://www.amazon.co.uk/ULTRAFIRE-W...&ie=UTF8&qid=1391086163&sr=1-1&keywords=xm-l2
I'm interested if thats any good, I think its from china thoughThorFire CREE XM-L2 T6 LED Memory Flashlight Torch Lamp WF-502B 5 Modes
another
Never owned these, someone test them
![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
Cree MC-E
bad desc
