Goddamn that's sexy! How many pennies?![]()
£89 shipped.
Is the ultrafire stuff on eBay any good compared to the previous one linked on amazon ?
Seems to be a large difference in lumens but little in price making me think false advertising,I don't have any 1865(?) or the charger for them so am rather reliant on aa or aaa.
I trawled the last 40 or so pages and came to the conclusion that even though my budget is £30 the Ultrafire 800 Lumens Zoomable Cree Xm-l T6 may be best as it has the zooming lens which i think would be helpful during late night treks.
Any other advice?
Just ordered the D80 too whilst having my usual morning OCUK browse, damn OCUK!So which batteries would be best for this? Standard or eneloops, guess i need to do some research and more spending!
£89 shipped.
Good find!If you're going caving I would strongly recommend against "cheaping out" - in a cave your torch is an essential piece of equipment and it's failure could be life threatening.
Zebralights are great, I'd easily recommend one![]()
Haha.I'll try to make it easier then - What would you use instead of the ZL or ArmyTek?
I'm not sure if it's the 105 lumen or the 70 lumen model. It seems pretty bright to me, but when underground it really isn't all that bright. Does last a fair few hours on 3x AAA batts tho. It's also too much throw and hardly any flood.
They both use 18650 batts, which are great in cold places (underground), and provide enough power. I'll have to carry a bunch of batts round with me tho, as max output can only be sustained for 2 hours. Excursions may well be longer than this.
Many people, myself included, find that the minimal drop in output is well worth the Warmer/lower colour temperature, which brings with it better colour rendering, less eyestrain and most importantly for caving, better depth perception.
Already knew about the CRI thing.Now that's a testimonial!Get the zebralight! I have the H600 and it's great, by far the best lamp I have or have had.
If anyone is after a hefty torch from a good brand then just found this for a cracking price:
http://www.gearbest.com/led-flashlights/pp_23214.html?currency=GBP&gclid=CM_-voC-xsMCFUPJtAodoCQANQ
