Anyone bought a Digital Multimeter from amazon and want to give me a link.
I think I might be looking at ones more suitable for a car
oo that a single AA?
can you get some pictures of it with your hand for scale? from the info it sound very durable, and might be the perfect light to go in the tool kit with a few spare sealed eneloops.
Has anyone ever used any AA to D Cell adapters?
I've got some maglites that take D size batteries, and I'd like to run them off eneloops. I know that a basic 1AA to D cell adapter is readily available... but I'm wondering about something that can put 2 or 3 AAs in parallel, keeping it at 1.5V but not being limited to the capacity of 1 AA.
I bought a couple for my mag lite but the way the rear of the maglite contacts the d battery means they wouldn't work. Would also be interested in a solution as I have everything else moved over to eneloops pretty much.
Same - I don't think my charger would fit an actual D cell. Hence the attraction of using eneloops inside an adapter.Don't think my Nitecore i4 v2 will charge D's :/
