- 31 May 2009
Thanks - it's a lot easier to put it together that way! Probably not as water resistant though.
So I took it out for the evening dog walk and compared it to my 900 lumen Fenix E35 UE, main thoughts.
1 - Build quality is OK, not perfect. Removed quite a few small bits of aluminium from the lanyard holes. There's a fair few machining marks/scratches on the body. Threads aren't well lubed and a little rough.
2 - Brightness is similar to the E35, maybe a little more floody, certainly not a huge difference. So if you've got an XML-2 based light this isn't going to blow your mind (No surprise, the XP-L too is essentially the same LED on a smaller package).
3 - Temperature - the output is a lot warmer than my E35, not sure that's a good thing.
4 - Temperature! - this gets really hot, really quickly on turbo. The E35 can run on turbo without any temperature issues (though it's annoying you have to hold the button down) whereas the BLF A6 gets uncomfortably hot very quickly. Think it probably needs some heatsinking.
5 - Flexibility - like to be able to customise the setup. I've put mine on 4 levels instead of 7 and turned mode memory on. Very nice setup that way.
Memory mode? The various levels I can understand, how does one set memory mode, and that sort of thing?
very cool. Never seen that let me Google it for you before.
