Thanks for the posts guys, I wasn't expecting such a quick response on an old thread, appreciate it!
I think the recommended torches are coming in at £40 and above which is still quite a lot for my use, especially when buying two.
Also, as CHokKA says, if it's like a compact searchlight, that's really good but having thought about it, where we are walking is fairly near some houses so I don't want to disturb people / draw attention to ourselves really.
Would you recommend something that's more towards, say, £20 per torch? Or is that just getting into poor quality territory?
I'm utterly clueless with torches so really have no idea on this subject!
Thanks.![]()
Also, on the subject of the Nitecore EA4, the output is adjustable so if you're worried about it being too bright when out at night, you can adjust the beam output to a lower output when near houses and that won't create much of a problem. I do this with mine all the time. The beam is fairly focused so you shouldn't cause too much bother anyway. I didn't notice that you were after two torches though. That might get a bit expensive!
In that case, something like the Fenix E05 or the Nitecore T2S are very good torches for the money. They are both powered by AAA batteries and kick out around the same beam. The Fenix is adjustable at 8, 25, and 85 lumens and up to 45m. The Nitecore is adjustable, at 2, 20, and 50 lumens and 28m. The Fenix is more powerful than the Nitecore but I have a Nitecore torch so I can't speak for the quality of Fenix on a personal level. I do know that they're very good though. The runtime on the Nitecore is better than on the Fenix, due to the higher output on the Fenix. If I was out walking a dog and didn't want a really powerful beam, and an inexpensive torch I'd go with the Nitecore, but you can get the Fenix a little cheaper so that might be a better option.
https://www.amazon.co.uk/Fenix-E05-...UTF8&qid=1464776266&sr=1-1&keywords=Fenix+e05
http://www.torchdirect.co.uk/t-series/nitecore-t2s-led-torch.html
