Yeah, it's a very good little torch. It has incredible power for such a small torch. I mainly use the moonlight mode for just lighting up enough of the path to see any obstacles, but it's good to have the full brightness there if you need it. It also has a magnetic base which comes in handy.
I bought a spare battery to go with it, too.
I can't imagine anyone being unhappy with this torch once you see the size of it and then the brightness of it. Maybe a bit pricey for some but it is quality and well worth it, imo.
The little usb charger is good, it's specific to the type of battery that's in the torch but they also do the same style charger (£10 or so iirc) for normal rechargeable batteries, which means I can charge up any battery from a power bank (when camping, mainly).
Eta: It does have one minor drawback in that if you hold the torch in your mouth you can feel an electric charge, not as bad as putting a 9v battery on your tongue but it makes you take it out your mouth quite quickly. You could probably make something that fits over the end that you could bite on if holding the torch in your mouth was something you did regularly. These days I tend to just use a head torch for those situations anyway so it's no big deal for me.
