Yeah headband seems decent and usb charging is handy for me.thanks
ali express do it for around £20 with the 18650 battery delivered !
this guy seems to love it
, says its replaced all he others, its the most comfortable headband yet
i think i will get this one then, cheers
If your local town is anything like mine or those near just pop into one of the many many ecig shops and Im sure they will have something.Torch geeks! I got given a torch which is great but it needs a new battery. Where can I buy a LC18650 battery from? My Amazon search didn’t find anything unless I want half a dozen and a charger.
I only need one and I don’t want to spend much.
Would B&M etc sell these?
They're not your typical alkaline batteries, though, so B&M probably won't stock any. They're not especially cheap compared to a AA, but neither are they stunningly expensive.Torch geeks! I got given a torch which is great but it needs a new battery. Where can I buy a LC18650 battery from? My Amazon search didn’t find anything unless I want half a dozen and a charger.
I'd stil be wary of using those unprotected cells.Oh, that’s a good shout. I’ll try that first.
@ttaskmaster - thanks for that, great info. I’ll think about ordering something in the future but need something for Wednesday -
Going to an off grid lodge for a few nights, I have a head torch each and a lantern but figured one more would be handy and it’s the only proper torch I have.
Shouldn't care what brand battery it is. Do you know if the built in charger ever worked? (or cable)anyone got an Electroflux EC01 ?
ive got Samsung 21700 40T battery in mine
and i cant charge via USB port (light not changing to red)
so I'm assuming you cant with this battery ?
I've always taken the battery out in the past and put it in a dedicated charger
but i thought i would try it via USB, and no charge ?
