It's this one here, i preferred the look of it over the usual black torches, also this is the warm white p60 host i was thinking of getting as well.
Ah ok, is there anyway to get more out of the one im getting or is 600 lumens fine?
So how efficient are leds and how much light could you possibly get out of an aa or 18650 battery if all the energy was converted to light?![]()
those are a bit disappointing in terms of their rated lumens-output but they're otherwise quite good.
At £20 each they're not even that expensive.
if they replaced the LED's they're currently using with XM-L's those things would be perfect.
Yeah I think I'll hold on a while and just see if they bring out any new versions with newer tech. Ideally I'd love to replace them with LED versions when they're brighter and maybe a bit cheaper.
9w is quite a difference to the 50w halogens, should save a fair bit of electricity as we have 4 in our kitchen. Plus I'd imagine that LEDs will last a lot longer. These halogens burn out after 6 months or so.
as long as the driver circuits aren't crummy the bulb units should last years without issue.How long do Manafront usually take to deliver?
