Can someone recommend me a decent walkabout torch please?
Oh, another thing - those of us with a lot of flashlights - do you go through buying and selling phases?
I've spent a bit recently (Mcgizmo Haiku XML the main expenditure) and as such it's pushed some other lights out of use - for example my 4Sevens Maelstrom G5 isn't getting much use atm so that's going up for sale.
I think I only ever have about 10-15 flashlights in my possession but I've probably bought near 50 over the last couple of years. The "oldest" light in my possession is an ITP EOS 3 on the Westfields keyring.
Whats your "oldest" LED flashlight?
Hmm, the only thing putting me off all those cheap XML lights is their poor regulation. yes, they might be super bright when you first switch them on but it's a bit disappointing to find out brightness has dropped to half after just 30 mins.
Requirements please.
Battery type, size, run time, how bright, tight spot or throw, durability etc.
That looks pretty awesome actually. £275 is a bit steep for a torch to keep in the car though...
, Bargain.I Go through buying phases, not sold any lights yet though![]()
If/when you decide to sell your Maelstrom G5 can i have first pick? i've been keen on one for quite a while![]()
.Need a recommendation for a light please.
I would like it to run on a single 18650 and be compact. Something like this sort of size and shape.
http://www.dealextreme.com/p/cree-q5-270-lumen-3-mode-led-flashlight-blue-1x18650-102524
It's going in my bag on night rides, so it's really just going to be a backup and for light if I get a puncture or other issue with my bike. Quite likely to end up with a bit of mud or water on it, so needs to be splash proof I guess and I don't want it breaking at the slightest whack.
Other than that, just not too expensive and available from the UK as I want it before Christmas.
Thanks.
Morning matey. what's your budget?
As far as lights in that form factor go, i think the shiningbeam S-mini is the best.
http://www.shiningbeam.com/servlet/the-152/ShiningBeam-S-dsh-mini-XP-dsh-G-R5/Detail
http://www.shiningbeam.com/servlet/the-208/***NEW***--ShiningBeam-S-dsh-mini/Detail
, which I can't be having if I'm out.
Sorry should have add, the only real requirement off your list would be to be able to use AA batteries with it really. Would probably use the torch for photography and night walks more than anything.
What batteries is everyone using?
I felt like that, i.e. must be AA batteries, but got fed up of the self discharge rates of them, not to mention the reduced power and capacity. So I bit the bullet and bought 18650s, since I wanted to carry on cycling through the winter.
