- 15 Aug 2007
- Outside in the bushes
Think he would disagree with that plan and kick you to Mars.
I don't think so there's plenty of the Chuck to go around
WEll why dont we build stuff out of it instead of steel then? The world trader centre probably wouldnt have fallen down if it had been
A building made out of spider silk would be covered in dead flies?
Well you could easily have a farm they dont take up much space do they? and then when they die you can collect them up and they will decompose and then you can dump them on the rainforest so it grows back again
Dragline spider silk is actually stronger than Kevlar synthetic fibre and Kevlar is several times stronger than steel! FACT!
Yet no one is disputing this.
FACT!
Rich
well i think you did, also spider silk is renewable
FACT!
Rich
Its strength to weight ratio is comparable to kevlar
God you post / talk some crud.
weight for weight of spider silk vs steel, spider silk is stronger - it's not the strongest thing on earth though is it?
Thats blantantly Chuck Norris.
Rich
Ok, then we need an experiment, lots of flies and a spider silk building. We just need to make sure they fly in the same direction and their wings are not stuck
