he's doing well. They are fitting mine tomorrow so amazing turnaround (quote was yesterday).
You must provide images or the Ban Hammer gets polished!!
Thats really quick! However, it all depends on the quote. Was your quote competitive compared to others?
Jacob was round here just now and again provided some very useful alternatives that i didnt realise was possible. I mentioned this thread and again he seemed happy his name is being spread positively. I was originally thinking of 1 unit in each of the bedrooms but he suggested having 1 in the loft with vents in each bedroom so its aircon in all the roomsDepending on the quote its highly likely i will have this done.
You'd think cheaper wouldnt you? One AC handler for the whole floor?vents I guess are more expensive than the wall ac unit? how much more expensive is it then?
What rooms do you spend most of your time in? You might find it expensive to run if you do plan to attempt to cool the conservatory but if you like to spend a lot of your time in there then perhaps that would be worth it for you.
I do wish I could have added my living room to my install but it would have required a separate external unit due to the location it is in the house. Leaving the doors open to my 3 bedrooms that have AC does help keep the living room cool if I keep the kitchen door shut (kitchen is at the back of the house with a lot of sun after mid day).
I also have the solar film installed on my windows at the back of the house which really helped a lot. I did not have it installed until end of August last year though so looking forward to seeing the temps in the kitchen this year if we get some more of the 37c days.
Deposit paid and due to start in AprilEnded up going with 1 unit in living room, 1 dining room facing kitchen entrance and the ducted unit to cool all 3 bedrooms in the loftDeposit paid and due to start in April
When I had mine installed in the dinning room to also cool the living room (French Doors separate the two spaces) it cooled the kitchen down quite a lot in the heat last year which I was impressed with.
Sounds a good setup, with the two downstairs that should do quite well - worse case you might have to use a fan to assist cool air into the kitchen.
It sounds like it is going to be a very slick setup! I look forward to some pics next month![]()
More than i wanted to spend TBH but if i'm going to be living here for more than 10 years its a worth while investment
It will also provide efficient heating in the winter months - Best used when the external ambient is above 5c.
But isnt gas cheaper than electricity?
I'd be surprised with the current gulf between the fuel prices....You tend to get more efficiency out of a Split in Heat Pump mode at certain ambient conditions than you would do with Gas.
Check the details of the units this should show the power input vs heating performance (COP - Higher the number the more efficient the unit)
