- 27 Aug 2005
Its very quick to cool down the rooms on full power, looking forward to using mine again this summer
Luckily got solar before the next summer but it's maybe 8kwh a day at most to keep it on all day for our 4 bedroom loft unit.For those who've owned units for some what type of increase have you seen to your bills over a year and over a typical UK summer?
It’ll be highly variable depending on setup and usage, but also consider the potential saving when using it for heating over gas/radiators.For those who've owned units for some what type of increase have you seen to your bills over a year and over a typical UK summer?
This was my concern, I'm in a flat and couldn't have a unit in my office, but the unit in the living room and my bedroom will cool the whole flat by leaving all the internal doors open. Sure, the office is a little warmer than the two rooms with the units, but it's not much different.Even having two internal units, being in the bungalow with doors open it cools the whole house.
30c in my room atm, wish I could justify proper AC but its not warm long enough![]()
Mine will be used heating too and should be significantly cheaper than gas boiler + radiators. It's more efficient and you're able to control the temp of individual rooms with more consistency.30c in my room atm, wish I could justify proper AC but its not warm long enough![]()
What are the maximum pipe runs you have on your units? I've been reading up but don't think I've managed to find a unit that'll allow runs greater than 15m and I could really do with getting to the loft which is 4 floors up from a potential compressor unit. I think an all-in-one solution would be the best bet?
Pipe run will depend on the Manufacturer, Haier run up to 20m.What are the maximum pipe runs you have on your units? I've been reading up but don't think I've managed to find a unit that'll allow runs greater than 15m and I could really do with getting to the loft which is 4 floors up from a potential compressor unit. I think an all-in-one solution would be the best bet?
