Cool, That is good news ! Sent you pm
Cheers on both
I will let you know when they arrive..![]()
Would you be up for making more?
I've bought 2.5" -> 3.5" adaptors for 3 drives. 3 different types and they all required the high TPI screws to be used to mount it inside my case.
My problem is that I have Antec cases with the silicon mounts and the included screw have a lower TPI count and don't fit.
If I PM you the dimensions will you let me know if you can do it, and how much?
TIA
Pete
DirtyJester, They have arrived and they look fanstantic, How much do I owe you ?
Ive PM'd you
Ok I am in the same situation just started this thread http://forums.overclockers.co.uk/showthread.php?p=16458717, is there nothing I can buy?
Hi DirtyJester, Cheers for the details, Check your PP, Hope the amount is correct !
Hi mentat sorry only getting back to you now matey but Ive been really busy ... to answer your question Im not honestly sure there is hence Ive been making a few (im sure youve seen the pics) for people that have wanted them and if you want a couple I happen to have 2 here ... PM or post if you want them![]()
