You got a fix for that please mate? Still not working for me.
Maybe I do.
Make sure you have not loaded any of the following apps before you try to launch the game:
FRAPS
DAEMON Tools Lite
MagicISO
PowerISO
or similar programs that let you mount virtual drives. The SecuROM anti-piracy system the game uses can interpret the presence of these apps as intent to pirate.
If you have tried to launch the game and failed, you need to restart your computer, make sure none of the above is loaded, then run the game as normal.
I always use FRAPS to take screenshots but I got the game working by not having FRAPS loaded before launching the game. To use FRAPS, I ALT-Tabbed out of the game, launched FRAPS, ALT-tabbed back and FRAPS then works as usual.
That works like a treat. Thanks mate.
Update: Haha. You have to love the difference between the dates written in the start video and what the guy says. Genius.
After playing for more than 10 mins, i get the feeling of Deja VU.......
Its not like the second one is it? I gave up on that one as soon as i had to replay the same map as the first one.
I own the first one but got bored within ten minutes of playing it. I might have another go though. Are there any mods that are must-haves/recommended for the first game? (Even though I've never played it before, well, I've played ten minutes worth). Such as graphical upgrades, mods that improve the game/gamplay etc.
Thanks.
I'll get it when they iron out any bugs (that's a laugh).
for software surround screenYeah, ****in hilarious...
CoP is actually VERY stable. I don't think I CTD'd once, and I've completed it twice (I have the RU version).
Sorry for being cautious.
S.O.C. was actually pretty stable for me. I played it all the way through without access to patches and had about 5 crashes to desktop.
Clear Sky patched however had a ton of script bugs so I couldn't progress, plus crashing to desktop a lot more than 5 times (including the initial launch, not a good sign).
So yeah, I'll wait for at least one patch before considering purchase.![]()
Do you not get a tessellation option under Advanced video settings ?
Maybe it is enabled automatically ?
