Regarding this, i am very aware there is a bow in the backplate.
I had to mod the backplate as this was the only way the card would fit the mobo.
i contacted Alphacool showing them the problem and the mods i had to do to get clearance.
this was their reply which i feel if fair enough:
It's obvious that Asus has not respected the Keep Out Area on this motherboard. We follow the ATX specifications for the development of all coolers, which describe exactly which areas around the CPU socket and the PCIe slot must remain free of components. With Micro-ATX mainboards, however, these specifications are often not correctly adhered to due to the available space. And the mainboard is definitely one such case where this has not been complied with.
i followed this up and asked about the warranty and they said they would honour any warranty
i am lucky as i have access to a milling machine etc so the mod was easy to do. I may have taken a mm too much off the standoffs hence why it looks bowed but have checked and there is still plenty clearance between the circuit board and the back plate.
at the end of the day the choice was wither mod it or scrap the idea and i decided to mod it.
its all fine and i am happy
the rudimentary video (not me best work
) shows the problem i had
if you compare the matx to the atx the clearance problem is apparent
