Yeah you can plane them out. Hell, I watch some american builders who hatchet it outWhat about planing the studs straight(er)? Take out the bow that way?
just sister the existing studs, then use packers/spacers on the top/bottom plate.
You'll have it done this way in 2 hours or less if you crack on
Not quite as simple because there are existing noggins there also.Like this?
)Ah, PU glue for the gaps.Looks like Wickes wood! And it's been shoddily constructed. It has been constructed in place, which is never a good way of doing things. Especially if they aren't very good at laying things out before construction.
I think you have two choices. You can add additional screws or nails to get it a bit more solid and then lay some 1"x2" quality timber over the top with spacers to get it nice and flat. The more spacers and screws you put in the better and you can use a foaming glue like PU glue to take up some gaps. You could just use spacers screwed to the wood but you have to mark where they are when you fit the plasterboard. And you will need a lot of them.
Or, you can just knock it down, get decent studs and do it properly.
Personally, I would correct it, even though its fiddly, it's less of a mess.
I did think about removing existing noggins but the board on the other side of the wall is screwed into them.
Great tip - when I thought I'd leveled it the first time I used a laser line as a reference point to measure from.YmYou could also use a string bob thing and pull the string across the room horizontally like brickies do, to see a common line you are working to if need be?
Just sister them proud enough that you can attach a piece of strip wood to the top vs. trying to cut down a piece of CLS. All I trying to avoid is the plasterboard going limp at the join to the ceiling by providing full length support.
I guess you could whack a generous amount of grip fill at the top and just sister vertically. You could sister horizontally at the top and at least have support/somewhere to nail an inch or so below the ceiling level.
I would remove the noggins and then fill and paint the wall on the other side. Pita but full height studs would be better, if you don't fancy that then the previous suggestion of fitting half height studs in-between the noggins is OK.
As for the question about spacers, just screw them to the top plate at 6 inch intervals then use a healthy amount of something like gripfill inbetween
Good tips there, thanks.
Regarding laying things out before construction, if you look at the first photo the shower pipes are a bit of a shambles, I did consider getting them redone, still might do as I want to redo some of the flooring.
Have you finished it yet sigma? It's 10am lad
