Nah, sod the hand saws. Just get a mitre and play around with it to get the acuracy. Stick a bit of tape over the section where the blade goes and cut through it. You’ll know know exactly where the blade will cut.
It’s a bit more difficult to quickly tell on the cheaper mitres but well doing that extra stage to get you more comfortable with it it’s more so with angle cuts but you’ll get it pretty quickly.![]()
Well, there are plenty of projects in mind, fitted wardrobes would be good, maybe a kitchen also... so I think a mitre would come in handy...
...let's do this small room first though
at current rate of progress it's a 5 year plan
