I am getting crashing in games, think lettuce was as well, generally they are fine..cooler and work a treat but for high res gaming they get hot after a couple of hours and crash back to the desktop due to the VRM's overheating so need to find a way to keep them cooler
Do you have the fan on the trad-2 blowing on the vrm's, if not try that. Try to have other fans that are higher up than the card (in the case) not blowing on the card but pulling hot air away and outside the case, along with the fan on the trad-2 and other fans under the card blowing toward the vrm's. Also try running it with one side of the case open just incase it's a airflow problem.
It should'nt really be crashing in games, i have run two 4870's with vrm temps 100+ in furmark which puts a heavier load than games and they never crash.
