The clean green energy thread - Lets talk about alternatives to nuclear power and how we can save th
Just looked at the wiki article for CSP (concentrated solar power), it does indeed look far more promising than photovoltaics, however there is more to feasibility than technology (and I am dubious of the efficiency of a long distance power grid) - the prospect of buying electricity form African states is even worse for energy security than oil. We need more home grown energy production - nuclear all the way, at least the countries selling uranium are mostly friendly.
Nothing wrong with HVDC and HVAC grids combined with smart grids.
Anyway full report thingy here http://www.pwcwebcast.co.uk/dpliv_mu/100_percent_renewable_electricity.pdf
It's not just power from north Africa, it is the most suitable renewable energy from all EU and north Africa countries, on a standardised smart power grid.
How do you store the energy for night time use?
CSP does that themselves. But the idea is a smart grid which covers every type of energy in all countries
Pumped storage works but requires massive invasive civil works. I doubt there are sufficient sites for pumped storage to meet Europes needs.
Smart grids can smooth demand profiles but lighting and cooking are fairly immediate demands that can't really be smoothed.
CSP may have some thermal lag allowing it to generate after the sun stops but I you would need vast vast thermal stores by current conventional standards to keep generating at meaningfull load factors for any time after the heat source is stopped.
Solar powered hydrogen storage makes more sense but captial costs will be heavy.
Nuclear technologies win out on practicality on so many levels.
read the report and csp already stores to generate all night. It;s not really an isue. seing as it works by heating oil to very high temperatures, then using that heat to drive a turbine.
For teh Uk yes, for europe wide, with different time zones it makes it far easier for a smartgrid, to be exactly that.
It's been mentioned earlier in this thread but what is wrong with nuclear fission produced from Thorium instead of Uranium? It sounds too good to be true, which usually means that it is - but it seems India is going for it in a big way, and China and Norway. From what I've seen (admittedly non-scientific) it's more abundant than Uranium, less chance of a meltdown and doesn't produce nuclear waste that can we weaponised.
Are the conspiracy theories true? That plans to build a new generation of Thorium powered nuclear power stations were shelved back in the '70s because they needed Uranium based fission for nuclear weapons production? But why would Japan go that route since they don't want nukes?
You're pretty much right on all accounts. It was easier to produce weapons material from uranium so that led the research, was adapted more for power production and given the amount of engineering that goes into designing the plants it didn't make sense to start up on something else when all the money was in uranium.
Thorium is more abundant than uranium, easier and safer to mine and stable countries hold huge deposits of it. And as you say the proposed implementations will produce far less waste that will decay to safe levels much quicker. I'm just glad it's finally being developed.
Umm, your figures are miles out.
Odd, as they're much the same as yours. The main difference is that you've included government subsidies and I didn't because I was talking about solar power and not about public money being spent on things that buy some votes.
Most PV run @ about £4k / kW installed (approx, varies if using polycrystaline or amorphous silicon). Either way you £20k for 2kW is way out.
It was out because I made a mistake - the panel I was looking at was 2.8KW and I misread it as 2.0KW.
http://www.discountedheating.co.uk/shop/acatalog/Grant_Solar_PV_2.8kW_Portrait_on_Roof_Package.html
I've just looked at various websites promoting solar power and they're giving figures of between £5K and £8K per KW.
Average solar radiation in the UK (varies with latitude) is ~ 1008 kWh / m2 / year.
So a 2kW array will produce approx (depends on may variables, so I have gone for a low figure here) 1500 kWh / year.
1500 kWh * £0.33 = £495 (feed in tariffs) / year
1500 kWh * £0.08 = £120 (electricity saved, very basic tariff) / year
That's a £615 saving / year
On a £8000 start-up, that's a 13 year payback. The feed in tariffs are good for 25 years.
That's overly simplified (depends if you get a loan, etc), but PV is viable (albeit only with FITs).
And the actual PV itself isn't viable. I think my estimate of £200 a year holds up pretty well according to your figures.
At £200 a year generated by a 2KW panel and with the middle price of £6500 per KW, it would take 65 years to repay, which is still far longer than the life of the panel and still ignoring the interest you could earn on the initial payment of £13000.
You could make a return on it, but that's due to the government buying the green vote and not due to PV.
Nuclear Fusion seems to be the best solution to fit everyone's needs. One thing I am confused about is the amount of energy required to heat the reactor up to so many million degrees must be an immense amount of energy. I think it's something to do with magnets and plasma, making super hot gas. Where would we get this energy from and how much energy is produced from the atoms fusing together compared to the heating up of the reactor?
That's essentially the problem now. Fusion requires the sort of temperatures you get in the core of a star (which is a giant nuclear fusion reactor). The magnets are what's used to contain the plasma because you're certainly not going to find any material that would hold it.
You can get vastly more energy from the fusion reaction than is required to make it happen - after all, stars do that all the time. The problem is doing it on Earth in a safe, controlled way. The best so far is JET with an output of 65% of input sustained for half a second. A much lower efficiency could be sustained almost indefinitely - they turned it off after 5 minutes because there was no point continuing with it once they'd proven that it could be sustained.
There are plans afoot to build the next generation, having learnt a lot from JET. That facility, ITER, should be able to sustain economic fusion (i.e. more output than input) for a little while and peak at 10x for a very short while.
They're talking seriously about an actual power station in ~40 years.
CSP using very high temperatures isn't so bad for that because it will continue to generate electricity for a couple of hours into the night from the remaining heat in the tank. Night usage is generally much lower than day usage, too. You do need something else generating electricity overnight or a lot of space for pumped storage hydro, but it's not as bad as it might look at first. Assuming you have enough sun in the first place, of course.
Molten salts are being favoured over oil now - they're not flammable, they're less toxic and they'll go to higher temperatures.
Can you give me an example of a CSP plant that generates all through the night? Last time I looked they didn't go all the way through the night, only into the night. Maybe molten salts made enough of a difference.
Aside from the frankly impossible levels of international cooperation/governments willing to put their entire country's economy/operation in the hands of foreign governments/groups who will inevitably use it to blackmail the others.
or if it all hits the fan use their supply for themselves and **** the rest off.
