Caporegime
- 11 Mar 2005
- Leafy Cheshire
OP seems to think, more = better, OP is wrong.
Youtube tags are supported. [youtube] [/youtube] and you put the ID of the youtube video inbetween the tags.Im confused how do you add youtube videos?
I like the design. Only think I would like is it enabled for Tap'a'talk on the ios / android. Makes browsing on the go so much better!
I'm a member of many forums and this is one of the biggest yet most basic i've seen. The default blue which which is just vile and if i'm not mistaken, the only way to change it is to user a browser plugin, then you've got no private message system, no custom avatar choice, no extra smilies and the biggest one for me is the no simple way to embed a youtube video. (yes i do know how but what a load of faffing about)
So why is a computer forum that specialises in high end computers and have tens of 1000's of members have the most basic forum out there?
Keeps it clean, there's nothing wrong with it.
Cant stand forums that allow any sig/avatar infact i tend to disable a lot of signatures on other forums as they take up half a page.
I do agree that i myself disable sigs and avatars to keep it cleaner but i do stand by my opinion that members should be given the choice if they want all the extras.
