Tiger Style: Build log
**Update**
Got a four boxes waiting for me this morning which contained :
Gotta love the smell of new hardware:001_cool:
So on with the build.....
Wanting everything to be as new meant everything need to look like it was fresh from the warehouse. So I made a start on the Alphacool plexitops which had become a little battle scarred from the numerous rebuilds I have done, nothing serious just a few scratches that needed polishing out.
1500 wet and dry paper does the trick :
But........Oh noes:o:crying:
Fear not though - Brasso to the rescue :
So while I had the pumps apart, giving them a clean I decided to do the 10W pro to 18w ultra mod. The pumps are easy to take apart with the impellor just being held in by magnetism. A slight push on the back and it all comes aprt easily (after removing the screws first!
This is a very easy mod all you need to do is join the 2 contact points at the end of the pcb (see my very dodgy soldering skills lol).
link
Tested and working fine, a successfull mod which should give the pump more power to pump through the chipset blocks I have in store :D...Sorted!!
Nice going so far.. All that stuff!!!!!!!!! lol
Thanks for mentioning the Pump mod, I will be doing the same to mine when I have a reason to dismantle my water cooling kit. :D
don't think I've been so jealous of a pile of hardware before. Seeing it stacked up like that on the table made me want money :(
Well I've been a little dishonest. The PSU and CPU were from my previous build and the keyboard and fan controller were bought recently from MM. Does look nice all stacked up though lol.
I've had a PSU start smoking and make a burning smell from using the 7v mod, seemed to be fine afterwards, but i swiftly put it in a non important pc :p
Molex provides :
12v | G | G | 5v
As standard the PSU can provide 12v or 5v depending how you wire the fan, with no side effects, since the motor is simply provided with a voltage and grounded.
When providing 7v, you give 12v to the motor and 5v to the ground (12-5 = 7), however the 5v is then fed back to the PSU somehow, through the ground line.
I dont fully understand it (im not an electrician) but this is how I understand it, and since my PSU went a bit dodgy, im reluctant to use it tbh. 5v for me, plus its quieter ;)
Yate-Loons are fine at 5v btw :)
Dont forget the motherboard.
The 10w is virtually silent. The 18w gives off a slight 'hum'. Other than that I can't see any difference? Be aware though that doing this mod will certainly invalidate your warrenty.
Very sweet work so far mate. Inspiration to us all tbh. Just one little question. In the pic below, you have 6 fans on the 120.3 if Im not mistaken, but apart form that fans is there something else you have attached to it?
It seems a little bulky for being a 120.3 with fans on either side.....might just be me though.
