Found this site...
https://www.tyrerunner.com/blog/how-to-use-a-tyre-tread-wear-chart
8mm
For a standard vehicle tyre, 8mm is optimal. For most tyres on the market, this indicates a brand-new tyre with zero wear and tear. Tyre tread of this depth allows for maximum safety and performance.
7mm
7mm of tyre tread is still great. At this point, the tread is only 15% worn. As such, the tyre will perform more or less, like new.
6mm
6mm of tyre tread depth is still relatively good. This indicates around 31% of the tyre tread has worn. By and large, a tyre with this tread depth will still perform like new.
5mm
At 5mm, you should start to notice a slight loss in performance. Not only will it take you longer to stop, but you'll also have a little more trouble keeping the vehicle in control throughout turns and in dangerous weather.
Nonetheless, this is still suitable to drive on. This indicates around 45% tyre tread wear.
4mm
At 4mm, your tyre tread depth is just barely above the level for recommended replacement. The tyre will now be approximately 62% worn. You'll unquestionably notice a difference in performance at this depth, both in terms of control and stoppage time.
However, that doesn't mean you need to replace the tyre yet. It's more or less safe and will still serve you well on the road; but you should start to keep a closer eye on your tyres perhaps increasing your monthly inspection to weekly.
3mm
It's at 3mm that your tyre tread depth starts to reach dangerous levels. At this point, the tread is around 78% worn.
You can continue to drive on the tread of this depth. Beware, however, that you'll need to take it a little slower around corners and in bad weather.
All major tyre manufacturers recommend the replacement of tyres at this tread level...and honestly, it's not only for their benefit they are saying this. Tyres at this level will take somewhere between 1 to 1.5 double-decker bus lengths additional distance to stop, and that's only at 30mph! One to keep in mind on the school run on a wet winter day!
2mm
At 2mm in depth, your tyre tread is around 94% worn. We highly recommend a tyre replacement at this point, as having such a worn tread is undoubtedly going to impair your ability to keep the vehicle in control.
That said, there is no legal requirement to replace tyres at this depth. The legal bar for replacement in the UK is actually very low compared to other EU countries, hence if you choose to drive on, you may want to consider doing so at a tortoise pace! Between this level and the UK legal limit, you could have as little as 100 miles remaining.
1.6mm
As noted above, 1.6mm is the legal minimum for tread depth on a tyre. Once your tyre tread depth falls below this figure, your tyres are no longer road-legal and need to be replaced.
We can't advise enough that replacing your tyres before they reach this point is highly recommended. If you skirt the lines of legal acceptability, you could accidentally go under this limit a lot easier than you might think - it could be as little as a jont down the shops away. An untimely traffic stop could, therefore, result in you receiving points, and likely a sizable fine.
Plus, it's plainly unsafe to drive on tyres of this tread depth. You'll become a danger not only to yourself but to other drivers as well. 27,000 lives in the UK are changed each year on our roads through death or severe life-changing injuries...the only thing in contact with the road is those scraggly tyres! A few extra mm could be the difference between stopping in time or not.
