Actually after reading up owners views on the wallpaper TV I would not recommend it due to the sound system it comes with is meant to be pretty weak sounding and very hard or impossible to upgrade
I've narrowed it down to either the LG 65 B8 or C8.
I would go with the C8 all day long. Differences from the website -I've narrowed it down to either the LG 65 B8 or C8.
I am tempted with the C8 however the guys over on avforums and a number of reviews seem to suggest they are pretty much identical in terms of picture quality and not worth the additional cost of £460.
This one not a G series but only that price for a 77"Indeed.
I paid the best part of 25k each for my LG G6's, now a better TV can be had for under 6k, all in the space of a few years.
75'' Sony XF90 is very close in price to the 65'' C8. Just sayin'
Size is everything. I don’t think you can ever have a TV that’s too big!
I was in the same situation as the op but was coming from plasma and really wanted the same and better picture but in end didn't want the headaches of babysitting a TV, due to image retention or burn in. Also wanted a large screen above 65 inches and 77 inches oled are stupid prices. I did have my heart set on a Samsung 82 inch but the image was terrible when I went to view it. So I checked other tvs and the 75 inch Sony xf9005 won clearly and the best upgrade in years for me and don't miss the plasma one bit.
Also op 65 inch is too small for the area you have and also light there so a 65 inch oled is not really right. Go see the 75 inch xf9005 you will fall for it and see it next to an oled 65 inch. You will be glad you did.
Still have mine!Wow, that’s a shame - is it a PZ80? I’ve had 2 Panasonic plasmas of that era and they’re fantastic sets.
65” looks a little small and 10ft is quite a distance away. I think you want a 77” if going for OLED.
At 10ft, I wouldn't recommend anything above 55", but opinions will vary.
