- 14 Mar 2011
Fill every corridor with pictures on the walls, no wilting and will boost the attractiveness. I've started using small AC units in smaller rooms (3/4x3) as patient comfort comes from taking the heat off the air rather than turning the room into a fridge. 95% thermal comfort using small units then larger ones in the larger rooms/corridors.
You can just space the large ones further apart, but the main reason for using them was that the janitors seem to need to fix them a lot less often... initially I used all small heaters and it quickly got out of hand!
. They survived long enough to allow me to complete the level. Onto the next level now next to the volcano, so far it is easier just because the layout is better.
