82 degrees tDie without the offset. tCtl was over 100. (vague recollection of seeing tDie at 112) My system does also have both a Vega 56 and GTX 780 in it too which adds a fair bit of heat. A big part of the problem with the my old EK block and the asetek coolers is that the finned area on the cold plate doesn't cover the whole Die area on the cpu let alone the entire IHS.i guess that was the tDie temp ,without the offset?
60 would be be a great temp to aim for as this machine is going to be rendering 24/7 - I see a few conflicting opnions which confuses the issue - some say 68 tDie (95 with the offset) is the max and throttling will set in and CPU lifespan is potentially reduced.
It would be great to get some more out of this CPU if poss, with current set up don't if I could make it to 3.975GHz / 1.325V though![]()
I've done some suicide runs on my cpu to see how far it would go and have managed 4.1GHz at 1.5V but it's sketchy at that level and it generates bucket loads of heat.
