mate its looking great so far. all you need is a hand grenade to go with it![]()
For some exploding pants !
Just had to edit this, as its not ace, ITS EPIC!!! you have an excellent talent there fella!
Subbed,
Can I suggest you use the Nuke Cola bottle as the res for the watercooling?? that would be excellent.
Also the coolant would look cool as a dirty oily substance![]()
How about get some opaque plastic film, add double sided tape to one side. Then cut the film into very thin jagged strips, peel off the double sided tape and place around the res picking a central "point of impact" so it appears to be cracked in a radial fashion. Back light the res for better effect, although this largely depends on your coolant colour and opacity of course.
If it looks pants, then at least its easily undone
EDIT: I see there phone screen protectors that have fake cracks to pranks your mates, might be easier with that...
I have no idea what to do to the W/cing parts.
