Victorian renovation build log
Well turned out it was 1.5m cubed which is 3.6 tons so off by a lot, thankfully used a mix on site company so not shortage of concrete.
Don’t think it’s too bad for a first ever slab with no help!
Looks good. What's the depth of it?
How far into the whole renovation are you? When do you reckon you'll be finished?
100mm average thickness for the slab
Ive got the hall, dining room, and 2 bedrooms to finish. It will take as long as it takes, we are in no rush, much more concerned about the finishes.
11hrs in work, 2 kids to bed and then on my knees floating the slab before it goes off :D
Never used self levelling compound before, lovely stuff to work with, very satisfying.
Over mixed it little and it’s dried with quite a lot of pin holes from bubbles but it will be covered with engineered wood parquet
Second coat of slurry going on the garage walls. This stuff is actually really nice to use and come in 2 different colours to make the second coat easy to get good coverage.
Wasn’t sure whether to get PVC garage door tiles or just epoxy the garage floor but having found the floor had no DPM I’m going to epoxy it.
Oh and also finished cutting the 9” skirting in the spare room
Nice secret door
That’s the access to the suspended floors of the hall and dining room, it’s only about 40x40cm!
Apologies for all the terrible photos as of late, I’ll try and take better ones.
Finished all the slurrry.
Tomorrow I will fit a dimple membrane to the stair well.
Then need to clear all this ready for the epoxy DPM and high build epoxy too cost
Still not chosen a colour yet!
Managed to put up a bit of the dimple membrane. You can plaster or dot + dab straight onto it.
It tucks behind the DPC, with all joints being taped with a very expensive waterproof plaster-able tape.
Wasn’t allowed to drill all the holes necessary for secure fixing as we have a poorly baby today!
Hasnt flooded in the 5yrs I've been there. It was very humid but no standing water and the soil wasn't wet when dug out, anf no wood has rotted in 150yrs!
With all the recent rain is has felt very damp behind the DPM however, so I imagine all my work will direct moisture somewhere, hopefully around the basement and garage and down the slope away from the house
Massive clear out of the garage this weekend and cleaned/etched the concrete with sulphuric acid.
Oh and sealed and fitted a mantle to the upstairs bedroom and started painting the skirting, will grab a pic later
Cracks and bug defects filled with damp tolerant epoxy filler
Whole floor primed with damp tolerant epoxy primer!!
Got my sweat on.
Using a suspended electric heater to raise the temp a bit and shorten curing (don’t judge :rolleyes:)
Fantastic work. We've a Victorian place I've been renovating over the past two years, it makes the work I've done (which I thought was a lot) look so small. Excited to see the progress. Looks like I'll have ours finished just before we are ready to move, so the next person will enjoy the fruits of my labour :o
4th bedroom’s chimney breast has been all sealed for a while, stuck a spare fireplace on it. Made a half arsed attempt to paint and position the skirting then got back to the 1st top coat on the garage floor!!
Think I would have just built storage along that wall and hidden the fireplace. I'm a huge fan of original features but that would do my head in haha.
@BigBoy - We had a great debate about the fireplace, all the down stairs ones are central, all the upstairs ones are off centre. Conclusion was to keep it in its original place.
@Hedge - The idea is to put smart fitted shelves in that alcove but after the skirting and picture rail have been fitted. It’s wider than it looks ~50cm
